Posted by Janicholson on December 31, 2011 at 13:30:53 from (96.24.99.126):
In Reply to: No power to starter posted by Tom300u on December 31, 2011 at 08:43:05:
THe first test is to take a piece of wire and jump between the big terminal from the battery on the Starter relay (often called a solenoid) to the littl terminal next to it. If it does not start, the big wire may be hooked to the wrong big terminal. If the terminal that is going to the starter motor from the relay is closer to the little terminal it is wrong. If it it correct, (close to the bat connection), and it does not start, I would be amazed. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
