Probably stick in two gears at once! Take out the three bolts that hold the shifter to the platform and remove it. Use a LED light or good flashlight and look into the hole. All the slots in the shift rails must be lined up across the middle. If one is not, use a large screwdriver, or small pry bar to make it so. Clutch down and TA lever back helps. Look in the archives here for a picture of the tip of the shifter. It may be worn and need to be built up. Jim Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
