The 6 volt starter is fine - I have that on my 300U, H and M all with 12 volts. Either your starter is bad or it is locked up against the flywheel. Try turning the motor using the fan - if it moves its not locked. If you can"t move it, back out the starter about an inch and it will free up. Move the flywheel slightly and tighten up the starter. That happens about once per year on all my tractors. It"s what happens when the ring gear starts to get bad along with the starter drive gear. Only long term fix is to replace both.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
