The easiest way I have found is to watch the valves in action, and stop when they are in a position that guarantees the position of the valve you are adjusting. The valves are either intake or exhaust. Use this on one cylinder at a time, it works on any 4 stroke engine of any number of cylinders. I put a shop rag over the adjacent cylinder's valves to assure I am looking only at the cylinder I am adjusting. Starting with #1 cylinder Rotate the engine until the exhaust valve –just- starts moving, then adjust the intake on that cylinder. Rotate the engine until the intake valve just stops moving and then adjust the exhaust. These two positions are located such that the cam is not pushing on the valves as you adjust it to spec. Do one cylinder at a time, and look at the intake and exhaust manifolds to assure it is an intake or exhaust. They are E-II-EE-II-EE-II-E From front to back Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
