Posted by pete 23 on December 31, 2011 at 16:40:01 from (74.32.238.142):
In Reply to: M will not start posted by Dudley Brand on December 31, 2011 at 15:20:02:
If it will run by spraying gasoline into intake of carb like you indicate I would just screw the main jet out a few turns to try. Once you get it running you reset it. There is no 100 per cent accurate setting for a dead engine, it is a starting point. Get her warmed up, run wide open , turn it in until starts to lean out, back out to running good and give it another half turn or so. Idle screw, set for best idle. Can be anywhere from half turn out to couple of turns depending on carb and engine conditions. And, the idle screw is air, so the farther out on that one the leaner on a M.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
