Can you reach the hex with a pair of dividers? That should get you close to the size of socket you need. Once you get No1 piston to TDC on the compression stroke and counting from the fan end of your engine you can now adjust valves 1,2,3 & 5. Then rotate your engine one full turn and adjust valves 4,6,7 & 8.
You can return the socket if it's too big or too small and get one that does fit. Once you feel compression drop a long plastic straw on top of the piston and you watch the straw rise as a helper hand cranks the engine slowly. Both valves on No1 cylinder should be closed when the piston is at TDC. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
