Re: F 20 mag questions and a few pics of the shop
Posted by 38F-20 on December 31, 2011 at 17:41:51 from (50.82.60.201):
In Reply to: F 20 mag questions and a few pics of the shop posted by Dave eklund on December 31, 2011 at 15:57:24:
If your friend's F-12 mag was a working mag off of your tractor, I would guess it is a grounding problem. Clean the bottom of the mag and the mag bracket with emery cloth to get a better connection. If either mag doesn't work off of the tractor, my best guess is a points and condensor set would do the trick. After that, there are a few other things to try, but these should be the best places to start. Using a drill to turn a mag is easier, but I always do mine by hand. Just wear a glove so the impulse doesn't snap and sting your fingers. Happy New Year.
