Posted by El Toro on December 31, 2011 at 20:25:10 from (108.3.225.57):
In Reply to: M will not start posted by Dudley Brand on December 31, 2011 at 15:20:02:
Disconnect the gas line at the carburetor and remove the tube fitting from the carb and look for a screen behind that fitting that may be plugged. If that looks clean hold your hand over the throat of the carb while a helper makes an attempt to start the engine. If there's very little suction means you have low intake manifold vacuum. Could be a leaking manifold gasket or isn't tightened enough. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
