If you are talking about just a cut-out, not a regulator, the generator will probably charge it OK. However, I'm not sure that once closed the cut-out relay will open when the engine is shut down.
Most 12-volt generators will badly overcharge a battery if there is no voltage regulator.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
