Re: Farmall Generator Cut Out
Posted by gene bender on January 01, 2012 at 02:41:46 from (67.55.227.172):
In Reply to: Re: Farmall Generator Cut Out posted by 38F-20 on December 31, 2011 at 22:13:12:
All the cut-out does is close thepoints when the gen is charging and then open when no voltage is at the gen terminal. Does your gen have the adjustable third brush cause if it has the cutout it should have it. Positioning the third brush does affect the charge rate the cutout doesent do that.
