Posted by Nebraska Cowman on January 01, 2012 at 04:34:46 from (66.252.115.26):
In Reply to: Magneto Setup posted by Ben Baun on December 31, 2011 at 15:14:17:
Either your 6 volt coil failed by being fed 12 volts or the pints are burned and pitted. If you want to revert to the stock magneto the best thing would be to send your magneto to someone to rebuild it. It's probably going to need a new coil and freshened up. I always recommend tearing them down so you can clean everything up and grease the bearings. Then it should be trouble free a long time. Nebraska Kirk does good mag work.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
