Re: '42 H Belly Pump
Posted by merlynr on January 01, 2012 at 08:29:59 from (166.147.65.58):
In Reply to: Re: '42 H Belly Pump posted by George Rausch on January 01, 2012 at 03:15:23:
Not to hijack this thread,but how much fluid does the hydro require. Is there a dipstick for the fill hole? I have 7"mower with hydro lift cylinder(non 3pt) that leaks a little when use and I don"t have a good way of checking level of fluid.
