Farmall H Water Pump Spacer
Posted by Mike Wilgus on January 01, 2012 at 11:54:06 from (75.218.31.110):
I am rebuilding the water pump on my Farmall H. I pressed in new bearings and seals. After I press on the pulleys and tighten the bearing retaining nut completely, the pulleys don't turn easily. I did add a new felt seal and there is some drag, but i believe it is more than is desired. The spacer that goes between the bearings may be worn, so when I tighen the bearing nut, I may be preloading the bearings.I don't know what the dimension of the spacer is to be. Does anyone have this dimension? I can't seem to locate a new one to purchase to I would like to machine a new part if needed.
