Re: 806 Engine
Posted by OldfarmAl on January 01, 2012 at 12:21:00 from (50.121.18.230):
In Reply to: 806 Engine posted by OldfarmAl on December 30, 2011 at 08:58:31:
Thanks a bunch Ya"ll. This info will be put to good use. I"ll call the salvage yard tomorrow. BTW just how much did the engine and rad etc from the 1206 cost?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
