Re: M alternator conversion charging issues
Posted by Jon Hagen on January 01, 2012 at 13:35:33 from (69.26.23.96):
In Reply to: M alternator conversion charging issues posted by Bill in il on January 01, 2012 at 13:09:02:
If voltage at the battery posts are not above 14.8V, everything is fine. The charge rate should drop back to just a few amps when the battery is full. Let it run a while longer and keep checking the voltage at the battery.
I am curious where the little Hitachi regulator kicks out. !4.2 is ideal, but many Delco SI series alternators have the regulator set at 14.6-14.8 which is higher than necessary.
