300 utility engine in 39 h
Posted by LEfarmallh on January 01, 2012 at 13:44:29 from (67.54.200.143):
I have a farmall h that I'm wanting to wake up.I have a 300 utility motor to rebuild. I assume that everything bolts up. the only difference I see, is the starter position on the tractors are in different locations. Is this a problem? Is the 300 worth the trouble or should I wait and get a 350? This will be a pull the sleeves out and run piston in the sleeve bore modification.
