Bill - If the battery is partially down, it could take 2 or 3 hours of charging at 20 amps to fill it up and for the charge rate to then taper off.
Try sticking a battery charger on it overnight. Then start the tractor and watch the ammeter. If the battery is good the ammeter should drop to +5 amps after only a minute or two of running.
However as Jon suggests taking a voltage reading across the battery is the best indication whether the battery is being overcharged.
Jon - The regulator on the Delco 10SI is temperature compensated. Depending on the ambient temperature output voltage at speed can range from about 14.2 (hot weather) to as high as 14.8 - 15.0 (temps below 0F). Thus you may see an apparent overvoltage condition in cooler weather when the alternator is actually performing as it should.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
