Posted by David G on January 01, 2012 at 15:07:00 from (205.215.206.18):
I took the bolster off my H this afternoon to look at the leaking water pump. I put a new one on this last summer, and it started leaking soon after that.
The packing nut was completely backed out. I tightened it up, but am thinking I should take it out, fill it with packing and go from there. How can I prevent this from happening again?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
