Re: IH 560 backfire miss
Posted by Janicholson on January 02, 2012 at 11:07:12 from (199.17.6.31):
In Reply to: Re: IH 560 backfire miss posted by Craigswanson on January 02, 2012 at 10:21:50:
An intake manifold leak (internal or external) can make the system run as described. When warned up it curves enough to seal pretty well, When cold it pulls away and leaks. Just thinking out loud. Does the choke make any difference? The point gap is supposed to be .020" on a high point of the cam.
Do check the distributor shaft wear. Jim
