Posted by mkirsch on January 02, 2012 at 17:41:04 from (67.253.161.186):
In Reply to: shiffter..706 posted by Morris roessler on January 02, 2012 at 15:11:29:
You are talking about the "56 series" style shifter.
It still has 1234 on one lever and HLNR on the other. The difference is, Reverse is on a separate linkage. You move the range lever to N, then swing it to the right and back for Reverse.
AFAIK it's a ton of parts an a ton of work to make the change.
Back in the day, it was a conversion kit. You can't get the kit anymore. It's a nearly 50-year-old tractor after all...
You would have to get the parts off a junked 56 series tractor. Only problem with that is everything is probably worn on the 56 series shift linkage too.
You'd be better off fixing the slop in your 06 linkage.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
