Re: Farmall 300
Posted by Janicholson on January 02, 2012 at 20:25:56 from (96.24.99.126):
In Reply to: Re: Farmall 300 posted by AL Moyer on January 02, 2012 at 20:09:37:
It is close to the power of a Early M. It has less cubes, but more RPM, compression, and Cam. The torque rise off of max HP will be less than an M, but they are so much handier than an M that the comparison fails. If it runs well and is straight, the lack of PS will make no difference. W/O PS they steer like an H. That price seems good. Oil pressure when warmed up should be above 20. When cold in the area of 75psi. Clean coolant, clean engine oil, and a working Tach (if equipped) will tell much. If the clutch pedal moves left and right 1/2" or more, it may have a lot of hours on it. Jim
