Re: 140 carb problem
Posted by Wardner on January 02, 2012 at 21:33:37 from (4.154.236.40):
In Reply to: 140 carb problem posted by Bob M on January 02, 2012 at 20:41:50:
How about the needle seat gasket? Is it there or maybe damaged.
Needle can't fully shut off the flow. Gas level in bowl rises above the top of the main jet outlet level and floods air inlet. Either that or there is a crack between the carb inlet fitting and the needle seat threads in the upper half of carb. I suppose that could be tested with 5 lbs of air and your thumb over the brass needle seat.
