The only real difference between a 306 and 309 pump (or a 314) is the plunger cut. The actual plunger is interchangeable between nearly all of those pumps (except for being match ground). IH made adjustments to each for different RPM settings and stuff like that so you will see different springs in use. Yes they will basically swap.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
