Re: F-12 Radiator Repair
Posted by Tom Fleming on January 03, 2012 at 14:45:41 from (206.193.250.146):
In Reply to: F-12 Radiator Repair posted by leaky radiator on January 02, 2012 at 18:12:53:
There are 2 places I go here in western Pa., both are in the Pgh area. One is Herb Brittner Radiator repair. Herb has been doing rad's for almost 40 years, and knows his stuff, especially on the old ones. He is kind of grumpy and short on the phone, but he is a good guy.
Other one is Bakerstown Radiator Repair in Bakerstown Pa. They also know their stuff and are a bit more customer oriented than Herb. However, they are busy all the time. both have contact info on the web.
How bad are the leaks? If that is an old, copper core and in reasonably good shape, you can actually solder the leak your self. Other option in a pinch is to use Barr's leak if the holes are small and on one of the inner tubes. I have done both, and both have turned out fine.
One note, if you use the Barr's leak, follow the directions, and expect to run the tractor, after it is up to temp at least 30 mins to circulate the product. If it is used as per the directions, it works wonder's for small holes and "seeping" type leaks/cracks. Too much, and it will cause you problems. 1 bottle of it, and applied as per the directions. Your mileage may vary...............
