Re: M starter problem
Posted by Larry Ks on September 06, 2000 at 03:52:19 from (205.171.70.144):
In Reply to: M starter problem posted by todd on September 05, 2000 at 21:03:32:
Todd...I think the guy below gave you good advice. I've got a SC that will do the same thing once in a great while, the bendix hangs in the flywheel. I simply loosen the starter mounting bolts and shake the starter, and it lets the bendix return to its home position, and then it works fine. No harder than it is to remove, and to satisfy my own curiousity, I'd pull the starter and hook it to a pick up battery with jumper cables and manually kick it in, and see how it works (this is what I did the first time). 12Volts won't hurt the starter, just don't run it too long.
Post A Followup
: Re: Re: M starter problem
