Re: Need Part Number for Glow Plug - IH 424 Deisel
Posted by jimb2 on January 04, 2012 at 16:20:56 from (174.115.9.174):
In Reply to: Need Part Number for Glow Plug - IH 424 Deisel posted by RTR on January 03, 2012 at 13:49:11:
Hi RTR, the following was provided some time ago
by Demaris:
Glow plugs are Champion AG28 or CH28 (155). Bosch
# 0250001001 or 0250001010 Lucas: DS104 Beru:
214GK
All are rated at .9 of a volt and 40 amps, i.e. 36
watts.
If you Google CH28 glow plug you will find one for
sale on ebay.
MJ is correct, the connections should be clean and
the copper wires between glow plugs will get warm
and that paint may start to burn. I don't know
where you are located so if you are in a warm
climate the painted wires probably not a problem.
Here in Canada it was -25C last night and the glow
plugs wires would be warm to hot for the tractor
to start. BTW DO NOT use ether on this tractor
while using the glow plugs.
JimB
