Re: REPOSTING: Plow Chief ofr Super Chief shares? (NEWPIC...
Posted by robgIN on January 04, 2012 at 19:23:06 from (76.208.0.64):
In Reply to: REPOSTING: Plow Chief ofr Super Chief shares? (NEWPICTURES) posted by Mike1972chev on January 04, 2012 at 14:30:06:
I would say neither Plow chief or Super chief in the pictures. The xx554 number on back of the share is for a 14 inch share like used with the older genius bottoms. Plow chief and Super chief look a lot different. Super chief uses a straight blade share all one piece, unless you find a deep suck share that will have a point similar to the older genius but not nearly as big. The Plow chief is similar to the super but uses 2 piece share with a separate spear point that is in the neighborhood of 2 inches wide and 6 to eight inches long. Surely somebody has some pics....I'll have to look.
