Re: Read this before you remove the balancer D-236,D-282,...
Posted by Wardner on January 05, 2012 at 00:20:33 from (4.154.232.60):
In Reply to: Read this before you remove the balancer D-236,D-282, others posted by Fritz Maurer on January 04, 2012 at 20:38:44:
Thanks for the warning. I wasn't sure how to go about it. It looks like a job I need to do in order to set up a front hydraulic pump on my 660.
It must be a hard pull. Should heat be considered? I suppose those pulleys are still available from CaseIH should there be a catastrophic failure.
I hope all I have to remove is the front sheet metal and radiator.
third party image
