Re: Farmall M Starter Switch Pin
Posted by willie in mn on January 05, 2012 at 01:30:21 from (64.12.116.73):
In Reply to: Farmall M Starter Switch Pin posted by SadFarmall on January 04, 2012 at 23:41:58:
There may be other methods, but this is what I would do.
Looks like 5/16 or 3/8 inch hole. Paw around in junk box to find the following parts- carriage bolt of proper length, small coil spring, 2 washers, & nut or cotter pin.
With your grinder, round off the end of bolt where it contacts the switch. Place spring then 1 washer on bolt, insert through hole in post, then a washer & nut. Use a dab of thread locker to hold nut, or if space permits, use a second nut to lock. Or drill 1/8 inch hole near end of bolt & insert cotter pin.
If you can find the parts in junk box, no cash spent. If you have to buy new parts, not more than 2 bucks. Time required-15 minutes, or 30 minutes if you stop to sip a beverage. The spring is to hold the bolt back & prevent vibration from rubbing a hole in end of start switch.
