Posted by wildbill57h on January 05, 2012 at 03:59:07 from (68.50.61.73):
In Reply to: Re: Cub carb posted by gene bender on January 05, 2012 at 03:19:00:
Thanks Gene. I did take the fuel line in to a parts store and got a metal setup to put in both sides but to sediment bowl side which was new started to pull out the first round of thread trying to crush the crush washer. I thought that would happen if I tryed it on the carb. The new sediment bowl took a plastic fitting of 1/8 mip with 1/4 hose barb.( went in easy I;m hopein it doesn't leak) I have a 1/4 mip to 1/4 hose barb but I can't tell if its different dia.. It does seem to have the same threads at 1.25. Guess if I tryed it it would only mess up the plastic threads. This is a "working" tractor so to speak. I am changing from low exhaust to pipe through the hood. I have a different hood tank and have Caswell-ed the tank and put on new sediment bowl and will change manifold. Painting will come later. Wanted to use it if we got snow to plow the driveway. I should have had this done but... We don't get too much snow in Maryland but when we do it nicer to plow the drive then to shovel. Only about 100+ ft double car wide but it was nice to plow. Plus when the plow is working I can do the neighbors driveways also. Thanks again, bill
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
