Posted by rustyfarmall on January 05, 2012 at 08:21:29 from (216.248.71.224):
In Reply to: 560 wide front for M posted by Jim Becker on January 04, 2012 at 15:24:01:
Mike, the wide front stability issue has been discussed quite a bit here on YT, and the general consensus is that a wide front axle does NOT add enough (or no) stability to make it a good reason to switch. Stability comes from proper ballasting of the REAR wheels and common sense while operating the tractor on slopes OR with a front end loader. If any tractor with a narrow front can be upset on a sidehill, adding a widefront axle will NOT make any difference. 70% of a tractors weight is on the rear axle, why would adding adding a wide FRONT axle make any changes?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
