Posted by Bus Driver on January 05, 2012 at 10:15:16 from (67.213.45.69):
In Reply to: 140 carb problem posted by Bob M on January 02, 2012 at 20:41:50:
I have never worked on a Bendix carb for a tractor. Zenith, Marvel Schebler and and the IH for cubs, yes. On the IH Cub unit, the discharge nozzle screws in the lower carb body at a point that is below the fuel level in the bowl. If the gasket leaks on the nozzle, fuel will leak out even if the float needle seals perfectly. The discharge nozzle projects upward to end in the center of the venturi. I coat that gasket with #2 Permatex a day in advance if possible before assembling it.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
