Re: 560 wide front for M
Posted by mkirsch on January 05, 2012 at 11:34:58 from (64.80.110.75):
In Reply to: 560 wide front for M posted by Flambeauone on January 04, 2012 at 15:24:01:
Yes, a wide front end only gives the ILLUSION of more stability.
If the wide front were rigidly mounted to the frame of the tractor, it WOULD be more stable, but it isn't!
There is a pivot pin right in the middle of the axle... As the tractor tips over, the front axle simply pivots and stays firmly planted on the ground.
The axle doesn't "catch" until it's too late. By then the tractor is tipped too far over for the front end to stop it.
Wide fronts mostly improve the ride.
