Re: Replacing the stud/bolt on a starter?
Posted by mkirsch on January 06, 2012 at 05:39:27 from (64.80.110.74):
In Reply to: Replacing the stud/bolt on a starter? posted by BigTone on January 05, 2012 at 13:44:17:
The stud can't be replaced without some specialized equipment.
It is SOLDERED to the field coil. You need to get that big hunk of copper hot enough to melt the solder.
Most people have those useless trigger-pull "soldering guns" or wimpy little pencil soldering irons. Those tools won't even touch this job.
You need a big iron that carries a LOT of heat to quickly melt the solder without damaging the wiring inside the starter.
teddy52food mentions a "soldering copper" which is basically a giant soldering "iron" that you heat up in an oven, or with a torch. Most people don't have those just lying around.
