The studs are not too hard to change using a torch. Make sure the field coil ends fit into the stud properly and are clean. Leave off all but the inside insulating washers and apply heat to the stud on the outside of the case. Once you have it soldered in you can add the other washers and nut.
I have use repair studs on Ford starters nut they have 5/16 thread. I have never seen one for the 3/8" stud that the Delco starters use.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
