Re: 350 row crop seal and bearing
Posted by CNKS on January 06, 2012 at 06:55:23 from (216.144.104.128):
In Reply to: 350 row crop seal and bearing posted by Jimmy Weber on January 05, 2012 at 20:41:47:
I assume you are talking about an axle on a H/M--up. ALL oil seals face with the lip, which usually covers a spring facing the oil. You remove the 4 bolts holding the cover and the seal, felt, etc comes out. Disassemble and clean it good then put the new seal and felt in. The felt goes on the wheel side of the seal. i don't think, in this situation, that you can reposition the seal, just push it in as far as it will go. As to the bearing, it is probably difficult without removing the axle and housing, I have the axle and housing off my Super M now, will reinstall it, then do the other side. I would pack the bearing before installation. If I am off the subject the same rules as to installation apply.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
