Re: how to adjust a fast hitch 311 plow
Posted by Janicholson on January 06, 2012 at 07:37:02 from (199.17.6.72):
In Reply to: how to adjust a fast hitch 311 plow posted by F-12 guy on January 06, 2012 at 06:16:03:
To the best of my experience, there is limited effectivness of the traction control. Does it work? ---some--- the system is pure mechanical, dealing with pull points and angles on ramps at the front of the hitch yolk. Do not depend on it to do much. I do not know whether your plow has a depth gauge wheel on it. If so, it can be set to limit depth. The touch control lever can be used to adjust the depth manually as you go if no depth gauge wheel is present. Your plow has enough suck if it will burry itself, so the issue is one of monitoring the depth. The angle of attack into the ground should be such that if the tractor was on a 8inch platform the plow should be sitting flat on the level ground (does not include tilt. as when only the left wheels are on the 8 inch rise). Jim
