Re: how to adjust a fast hitch 311 plow
Posted by D Slater on January 06, 2012 at 09:14:17 from (184.15.2.95):
In Reply to: how to adjust a fast hitch 311 plow posted by F-12 guy on January 06, 2012 at 06:16:03:
Fast hitch cylinder should have a rod to set depth. If hitch keeps going down the cylinder is leaking internaly or the check valve at rear of the steel line is not holding. Or front of tractor is raising. If the mechanical traction control is working correct a 350 with a 311 will try to raise front off the ground on a hard pull. Higher you raise the handle the more the fast hitch will try to raise the plow on a pull. Or more weight shifted to rear wheels. Pin for down pressure needs to be removed for plowing.
Prongs on the plow have adjustment holes mounting them to plow, moving prongs lower will help the plow go shallower if I remember correct.
