Re: Question on water pump packing
Posted by Owen Aaland on January 06, 2012 at 18:35:11 from (216.47.33.149):
In Reply to: Question on water pump packing posted by David G on January 06, 2012 at 15:58:36:
The packing is the seal.
If you over grease the bearings the grease should come out the front by the fan. (The front seal should be installed with the lip forward to seal out dirt that is blown against it by the fan.) If you over grease the impeller shaft the grease will be forced into the cooling system.
