Re: Icing carb heat riser assembly
Posted by Owen Aaland on January 06, 2012 at 18:55:18 from (216.47.33.149):
In Reply to: Icing carb heat riser assembly posted by Rich8262 on January 06, 2012 at 02:38:08:
The heat riser parts do not come with a new manifold. The parts should be available from a dealer.
82958R2 - Spring
69443R1 - Bushing, 2 used
141159 - 3/16x1 dowel pin
85700R1 - Valve
82959R1 - Shaft
85699R1 - Weight
The valve has to be welded to the shaft. The shaft, valve , and weight have to be positioned correctly when assembling the parts.
