Re: Question on water pump packing
Posted by redgems on January 06, 2012 at 22:08:27 from (184.223.244.218):
In Reply to: Re: Question on water pump packing posted by David G on January 06, 2012 at 16:50:09:
The fellas are correct on the seals and packing.
As to your question of grease, yes ,it helps. I have a 400 restoration and I rebuilt pump with all new ,kept having slight leak ,kepted adding packing and tightening nut to no avail.I hesitated on grease because I did not want fan dirty. Well, not until I shot grease few shots at a time ,did it stop.Been a year now and no leak or grease splatter. Tony
