Re: Hard to find O14 starter
Posted by James Williams on January 07, 2012 at 06:19:04 from (69.251.26.114):
In Reply to: Hard to find O14 starter posted by chuck kaufman on January 06, 2012 at 15:36:30:
Chuck,I have a F14 with a starter system on it.First question is ,is a F14 Farmall the same as your O14?If so I used a 3bolt flange starter from a W series tractor and a starter from a A B or c so the pull rod could be used.Then I drilled the mounting holes out one size larger becaues the starter had two be moved away from the flywheel just a little.It works perfect
jimmy
304-582-9995
