Re: Any tips on getting the big nut off the front of the ...
Posted by D Slater on January 07, 2012 at 06:37:42 from (184.15.2.95):
In Reply to: Any tips on getting the big nut off the front of the crank? posted by sflem849 on January 06, 2012 at 19:26:54:
Think 2-1/2 is correct, will check when I go to shed and edit post if wrong. If the oil pan is coming off, place a wood block inside to block crank from turning. On a hard one with pan still on and engine out, a metal strap bolted to flywheel and a chain from it to block or plate. One inch drive socket and a long cheater pipe will do the trick sometimes when my impact won't budge it. On some it looks like a big chisel and hammer are the tools of choise. I work alone so thats what I do on difficult ones. Less difficult ones a impact will work good. Or a high power impact works on most.
Looked at socket I use and had to correct from 2-1/4 size to 2-1/2.
sflem I wasn't recomending the hammer and chisel. Just mentioned that looks like a good bit were removed that way in the past.
This post was edited by D Slater at 15:17:38 01/07/12 2 times.
