Re: how to adjust a fast hitch 311 plow
Posted by AJB-830 on January 07, 2012 at 09:52:54 from (50.105.135.90):
In Reply to: Re: how to adjust a fast hitch 311 plow posted by F-12 guy on January 06, 2012 at 17:09:11:
Josh, I would think your problem is with cylinder or check-valve. I have a 400, 350, and 450 all with fHs and the cylinders will not drop from the set position on any of them. Since you don't have a guage wheel, I believe only the cylinder keeps your plow from dropping. I have never taken a cylinder or check-valve apart, so can't help you with that. Maybe someone else can. Al
