I called my neighbor and he has a 3/4" drive impact. I will call around and see if there are any 1" impacts available. My little toy air compressor won't run it, but I can get the 100 cfm at 125 psi engine driven out of the shed. :lol: It kind of stinks because the MD is parked in front of it.
Thanks for the socket advice Slater. I was considering the cold chisel on this one as well. This is my parts motor so it is already out of the tractor. The pan is already off and it is sitting on it's side. I was kind of dumb though because I took all the bearing caps off the measure and now it is all screwed up because all the pistons are pushed up to the top. I will probably want to put two end bearings on the crank so the wood has more to push against.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
