Re: Stumped on H 6 volt positive ground
Posted by Novice with Case on January 07, 2012 at 13:15:13 from (68.191.137.189):
In Reply to: Re: Stumped on H 6 volt positive ground posted by pete 23 on January 07, 2012 at 10:38:56:
Hey Pete, You are my hero! I just finished checking out the system as you advised. It turned out to be just as you suggested. The contacts needed to be adjusted to open and close at a lower voltage. My VR required bending the tab but with a little trial and error I got it charging like a charm. The generator kicks in on starting and the points open the circuit when I shut it down. Thanks for the help!
