Posted by Novice with Case on January 07, 2012 at 13:28:52 from (68.191.137.189):
In Reply to: 240 PTO seal removal? posted by Lukesdad on January 07, 2012 at 11:25:31:
If it has the orginal seal you may have to remove the 6 bolts holding the entire casting to knock it out from the back side. I have spent a lot of time trying to pry out an orginal seal from around the shaft without damaging the sealing surface. The old ones were made much different than the replacements. They are thicker and tough to take out from the front. If the seal is a newer style they can be removed easily from the front with a screw and slide hammer.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
