Re: how to adjust a fast hitch 311 plow
Posted by mkirsch on January 07, 2012 at 14:55:11 from (67.253.161.186):
In Reply to: how to adjust a fast hitch 311 plow posted by F-12 guy on January 06, 2012 at 06:16:03:
The stop is not meant to hold up the cylinder. It is meant to push a button on the body of the cylinder that bypasses the hydraulic pressure and makes it stop retracting.
It still depends on the seal inside the cylinder to hold the load.
A plow puts a LOT more down force on the cylinder than just sitting in the shed. The friction of the stop clamped on the cylinder was enough to hold the drawbar up, or even the raised plow, but the pressure of the plow digging will slide it without a doubt.
