Re: Stumped on H 6 volt positive ground
Posted by gene bender on January 07, 2012 at 16:07:04 from (67.55.227.172):
In Reply to: Stumped on H 6 volt positive ground posted by Novice with Case on January 07, 2012 at 08:04:08:
Is the regulator made for the three brush system as they do list two regs for those gens. Are you sure you have the wires on the correct terminals. Your new reg probaly doesent want the wire going to the lite sw. Just because you got a new reg doesent mean you have the rite one. The Delco # on your gen must be either 1101423 or 1101355 and originaly had a cut-out.
