Re: Stumped on H 6 volt positive ground
Posted by gene bender on January 07, 2012 at 16:09:48 from (67.55.227.172):
In Reply to: Re: Stumped on H 6 volt positive ground posted by Novice with Case on January 07, 2012 at 09:13:54:
Loosen up the screw on the carb end and move the brush farther away from the fixed and the out-put voltage will be lower as 8.6 is a little high.
